215/55 r16 E-320
Old Jan 17, 2007 | 12:05 AM
KINGGLORY's Avatar
215/55 r16 E-320
I just had a pair of Continental ContiPremierContact installed last week. Installed on a 97 Mercedes E-320 the tire dealer ordered them from Tirerack. Anyhow, I had to take the car back 3 times for balancing. I was told a wide aray of BS to explain this. "The tires are more nylon today and take several miles before they can warm up and balance up correctly." They rebalanced all 4 and all 4 were off I am thinking mounting error from the tech.
The other time they claimed that they all needed to be matched and this is a common thing. I was thinking then do it the 1st time.
This time they are blaming the vibrations to my brake pads.
I went to get a new alignment and they recomended 2 new lower ball joints. This maybe the issue. What do you think?
I did also noticed that these tires are loud. My truck is smoother then these donuts.
I am thinking of returning these but what would be a better all season tire?? The dealer will put up a fight but its my $$.
Any suggestions would be awesome.
Old Jan 19, 2007 | 09:54 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
souonds like the balancer needs to be calibrated .... and yes what you were told was smoke and mirrors ...
ball joints would not cause a vibration
as far as the stiff ride ... check the air pressure
