Does anyone know the offset for W209 CLK rims? isn't 35mm???
Old Sep 19, 2002 | 06:48 PM
vivianlove's Avatar
2002M3
My plan is to replace the stock rims to 18" rims, do I need to lower the spring or change spring???
Any help would be nice!
Thank You in advance!
p.s.
no 18"+ rims - not a very good idea in Chicago
Old Sep 19, 2002 | 08:04 PM
CLKfanatic's Avatar
you don't need to lower the car, but your car will sit a lot higher with the 18" rims on and it will look really bad...so i guess you should put new springs on....
Old Sep 20, 2002 | 12:54 AM
Lynn's Avatar
If you use a lower aspect ratio tire to maintain the same diameter as the stock wheels and tires, the ride height of the car will not be changed.
Old Sep 20, 2002 | 02:33 AM
vivianlove's Avatar
2002M3
CLKfanatic and Lynn: thanks for the reply
more questions:
What is the offset for the w209 CLK??? isn't 35mm???
Let's say the CLK offset is 35mm - Can I put a 37mm offset rim to it? or vice versa???
Thank You Again
Old Sep 20, 2002 | 11:45 AM
Lynn's Avatar
7J X 16 ET37 205/55 R16
7J X 16 ET37 205/55 R16 (FRONT) 8 x 16 ET 36 225/50 R16 (REAR )
7.5J X 16 ET37 225/45 R16
7.5 X 17 ET37 225/45 R17
7.5J X 17 ET37 225/45 R17 (FRONT) 8.5J X 17 ET 30 245/40 R17 (REAR)
7.5J x 18 ET37 225/45 R17
The above are all the available sizes for the CLK500 and CLK 430 Cabriolet from the MBUSA.com build your own web page.
Old Sep 20, 2002 | 10:58 PM
vivianlove's Avatar
2002M3
more questions:
Thank You Again
I'm mod illiterate
No one seems to answer my offset question...
sorry, if you're already did...
What is offset? What is offset do? How does it work?
Thank You
Old Sep 21, 2002 | 04:02 AM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
Lynn did actually answer your question, just more in technical specs:
If you look at the post, "7J X 16 ET37 205/55 R16 "
ET37 represents the 37 positive offset
