Wheel offset question for 2000 E55 19" - Luke?
Old Feb 15, 2007 | 11:01 PM
Benz-O-Rama's Avatar
Easy question:
Will 19X8.5 et38 and 19X9.5 et38 fit on a 2000 E55
Thanks guys.
Old Feb 19, 2007 | 05:36 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
offsets are close enough but, be careful with the brake clearances as not all wheels with the same offset have the same amount of brake clearance
Old Feb 20, 2007 | 12:01 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
I say no on the front unless you go with a 235 width tire. Using a 245 width tire I could not move the offset inward more than 4mm. I went from OEM 18x8.0 et31 to aftermarket 18x8.0 et35 and that was maximum with only a 4mm change in offset.
A 8.5 et38 would push the tire/rim inward by 13mm. When Brabus made 8.5 width rims for W210 the offsets was around et26
Old Feb 20, 2007 | 04:32 PM
we have fit 19x8.5 ET37 on several W210 E55's with no issues using 245 tires
Old Feb 22, 2007 | 08:33 AM
Thanks guys!
Old Feb 23, 2007 | 12:49 PM
E55 KEV's Avatar
Veteran: Air Force
I wonder if my E55 is somehow different? I had 18x8 et35 that rubbed with 245/40/18 Nitto 555 and with Dunlop 9000 no rubbing buy no more room to go inward?????
If I remember correctly years ago I test fitted this 17x8.5 et30 and the rim touched the cradle. I am not sure but it may have been that the rim rubbed on the caliper. I no longer have the rim to play with:
