Technical help for wheels
Old Feb 21, 2007 | 04:23 AM
chixdiggit's Avatar
W209 CLK
I am a little confused about wheels.
This is my understanding. Although all Mercedes share the same 5x112 bolt patterns, there are two different lug sizes (12mm & 14mm) depending on the model. Smaller vehicles with the likes of C, SLK, and CLK use the 12mm width bolts while E, SL, CLS etc uses 14mm wide bolts. Offsets are different depending on the yeah and model as well but are very similar. Because of the different width bolts, these wheels are not interchangeable. This is because 14mm bolts will not fit in the holes meant for a 12mm bolt and using wheels that require 14mm wide bolts on a car that uses 12mm is dangerous because of the excess spacing around the bolts.
How is it that people are using wheels from say a W211 E class on a C class without any issues?
If the manufacturer uses the same wheels for all models? For example Renntech monolites have the same parts number for all the vehicles so I am assuming they would be the same rims. I would assume the wheels for the SL will be the same for a CLK?
I've come close to purchasing wheels but backed out in fear of the bolt issue. Sellers on eBay always seem to claim that their wheels fits across the board which I don't believe. I read what some members post regarding their rims and it doesn't seem to make sense. Can someone ie Luke or an expert put this issue of mine to rest?
Thanks!
Old Feb 24, 2007 | 11:00 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
here is a picture of the 12/14 bolt issue
as you can see the 12mm bolt does not seat properly in the 14mm seat. Many aftermarket wheels use conical seats rather the the OE designed ball seats so, the 14/12 problem does have any effect since the cone shape is the same for both sizes. Larger MB's run higher offset due to the needed load capacity
Old Feb 24, 2007 | 11:21 AM
raymond g-'s Avatar
99 E320
clarification, in part....
E series will use either 12mm or 14mm bolts, depending on year. Seems the
W210s came from factory with 12mm/12mm bolt diam/ball....whereas the W211s
came with 14mm/14mm.
Old Feb 26, 2007 | 08:09 AM
Originally Posted by raymond g-
the
correct
