To those w/ the Koni yellows....
I am in the middle of swapping out my rear shocks (the Koni's will be in tomorrow). Did you all re-use the black plastic cover that goes over the shaft as well as the rubber bump stop that goes under the plastic cover?
Ok- that makes sense. I just didn't know if these pieces were needed at all when swapping shocks. But I guess both should be used. A rubber snubber was cushion the blow to the shock in the event it would bottom out. A plastic cover would help keep the elements off the piston/shaft.
