Rubbing tires?
Thanks,
When your tires rub, you will definitely know. The first couple times can be a frightening experience, and it never becomes something you can just ignore.
What size tires did you get?
They're 245/40-17's in the rear and 225/45-17's in the front, same size as the stock tires, on the stock AMG wheels. The tires have plenty of clearance I think but a mechanic friend of mine was in the car, heard the sound and said the tires are rubbing?
It sounds like sort of like a squeak or rubbing, but I guess it isn't rubbing then. Could be the shocks/springs? I hadn't heard this before I changed the tires, and it's only on a bump where the rear of the car (I think left rear) moves up and down significantly.
