Will these wills fit my car?
Thanks,
Chris
Chris, usually SL wheels have low offsets like 25mm and difficult to fit on E-Class. What are the offsets which is usually stamped on the back espressed as et25.
Thanks for the reply, but I couldn't find any offset on the back of the wheel. At least, it wasn't obvious. Would I be able to fit it with spacers, hubcentric ring, etc.?
Thanks,
chris
It should fit on your E, but may stick a bit and need some fender rolling. Tire sizes are perfect.
R129 SL uses 12mm, R230 SL uses 14mm
