Disassembly of multipeice wheels...?
Old Feb 22, 2008 | 08:54 PM
deyainrdy4ds's Avatar
w208
im going to have to disassemble some multipeice wheels so i could get em powdercoated....face in flat black and lips in gloss black....
is this a process i can do myself (just seems like removing bolts) or do you guys recommend going to a wheelshop or somewhere to get it done professionally...if so what will the cost be like...?
Old Feb 23, 2008 | 05:25 PM
rdsesq's Avatar
Obsidian Black C350
Which ever way you go, be sure to use new bolts when they are put back together.
Old Feb 23, 2008 | 08:05 PM
w208
why?
Old Feb 26, 2008 | 12:51 AM
rdsesq's Avatar
Obsidian Black C350
Originally Posted by deyainrdy4ds
why?
When a bolt it torqued, it stretches. That stretching affects the force the bolt can apply. Most bolts for such applications are designed to be used once because of this torque stretch. You could reuse the bolt, but the bolt will be more prone to potential failure.
