Hello Luke.
My name is Khalid, I was wondering if you could give me some insights on wheel measurements. My aim is to have them fit right on,with no need for spacers etc.
I am getting custom wheels (rims) for my CLS 55 and was wondering if you guys could just double check to see that all the measurements were right if possible, before i can order the tires?
Front Rim size:
9" x 19" , Offset 26mm (rim comes out 5mm, compared to stock 8,5" x 18" ET 25), calliper clearance 47mm
Rear Rim size:
11" x 19" , Offset 32mm (rim comes out 15mm compared to stock 9,5" x 18" ET 28), calliper clearance 27mm
tires I am aiming for will be similar to the setup below, If my specs are all right
19x9 front 265 30 19
19x11 rear 305 30 19
Khalid
Front Rim size:
Rear Rim size:
Khalid
TR Moderator & Tire God
the specs you posted will fit the car but, is a very aggressive application and will most likely require some additional fender work to avoid rubbing
Quote:
thanks for the reply!Originally Posted by Luke@tirerack
the aim was to get it all done so i do not rub, my car is not lowered.
Which bit is to aggressive?
and do you offer PS2's in these sizes?
Luke is right.
I have seen the following work.
19 - 10.5 +32 rear OR
20 - 11.0 +36
They have no rubbing issues on stock suspension.
i don't think the 305 will fit withour rubbing.
Something like 295 or even 285 should fit.
I hope this helps.
20 - 11.0 +36
I hope this helps.
Currently Active Users (1)
