fitment?
I was wondering if these will fit on 2008 w211 e350 with sport suspension.
Bolt Pattern: 5x112
Offset: +32mm
I am not to familiar with wheel spec info, what is the main differences between an offset of +32mm vs one of say +35mm. Also is it better to have staggered wheels? Or is it just mainly for look?
Also what tires would be required for these rims on the w211 e350?
If I am looking for 19'' staggered wheels for my car, what wheel and tire specs fit best.
Anyone with advice is greatly appreciated.
Thanks very much
John
specs you posted are the correct ones. For example, I have 20x8.5 offset
32 on front and 20X9.5 offset 32. These are HRE's and this is what is recommended by their company. So as long as you have this offset on the
front and rear you should be okay. Tires, I went with 245/35/20 front and
275/30/20 in rear. with 19's I would probably go with 30 profile up front and
25 in the rear. The offset goes like this, the higher the # the further the
spacing of the actual wheel from the hub. So a 36 offset sticks out further
than a 32 offset. Sorry if I confused you. I'm actually selling my 20's if
interested or if you have anymore questions. I know what it is like to have
no one answer a post. Hope this helps!!!! Oh yeah, Staggered wheels is the
only way to go with these cars.
I dont think you are typing what you want to say, because it doesn't make any sense
