need tire size recommendation!!
Old Feb 4, 2003 | 12:35 AM
SiLvaC32's Avatar
C32
which is the best tire setup? for performance and look? perferably performance. if my rim is 19x8.5 ??
i have no clue... :o
THANKS!
jerry
Old Feb 4, 2003 | 01:13 AM
Harris's Avatar
Re: need tire size recommendation!!
THANKS!
jerry
For 19x8.5, you have 1 choice: 235/35/19. Probably you are going to have 19x9.5 at the rear, then the most common size is 265/30/19.
Old Feb 4, 2003 | 02:36 AM
SiLvaC32's Avatar
C32
265/30/19 in the bak?? isn't that kinda narrow?
and is 19x9.5 a good choice for the bak??
will i have tire rubbing problems with this setup?
THANKS!
Jerry
Old Feb 4, 2003 | 03:06 AM
Harris's Avatar
THANKS!
Jerry
Narrow??? W203 is a small car, 265s are "fat" tires!!! 265 is fine. If you're getting 8.5 in the front, then 9.5 should be for the rear. If you're getting 8 in the front, then it will be 9 at the rear.
C32's fenders are supposed to be pre-rolled in the factory. There shouldnt be any rubbing problem IF you have the correct offset/fitment.
Old Feb 4, 2003 | 03:13 AM
SiLvaC32's Avatar
C32
hmm... oops... i was thinkin about the 30... i thought 30 is the width of the tire and 265 is how thick the tires are.
Jerry
