need a quick answer...
Old May 21, 2009 | 01:55 AM
frostie_122's Avatar
...nothing
im trading 17" monos for 18" monos and the tires on the 18" are 245 in the front and 275 on the rears. 18x8 18x9 et31 et35
they fit on his clk and i believe were on a sl.
the car is a c43 stock height.
can i run these just to get home from the swap?...3hr drive.
i know when i lower it they wont stuff.
thanks
Old May 21, 2009 | 09:13 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
wheel specs are appropriate for your car but, not the tires
the tire sizes you need are 225/40-18 front and 255/35-18 rear
Old May 21, 2009 | 12:43 PM
...nothing
correct... i know that. the question is on a stock height car and a three hour drive will it work?
Old May 21, 2009 | 08:25 PM
...nothing
..and i have heard guys running 235/35 and 265/40 and no rubbing. is that true?
Old May 22, 2009 | 07:58 AM
235/265 would be really tight but might work with some tweaking of the alignment (more negative camber)
Old May 22, 2009 | 01:05 PM
...nothing
so at stock height can i run the 245 and 275 just to get home?
Old May 25, 2009 | 03:07 AM
...nothing
just to give a heads up...i drove to portland with the stock 17", and traded for the 18" with 245/40 and 275/35 and they fit and dont rub.
thanks for the responses.
