Hubcentricity
Old Feb 17, 2003 | 09:53 AM
Adonis's Avatar
CLK 320
Hubcentricity
My monoblocks start to shimmy at about 60mph. I had them checked and they are not bent. I was told i need a hub centric adaptor. How do you make a wheel hub centric. I'm not sure how this all works. Could someone offer any suggestions.
Old Feb 17, 2003 | 02:49 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Who sold you wheels that did not have the correct Hub ring or did the hub centric ring come off? What wheels do you have?
Old Feb 17, 2003 | 06:30 PM
Adonis's Avatar
CLK 320
I have brabus monoblock v's. they didn't have hub rings on them when i bought them. I had some plastic ones installed today and the ride is a little better but i still have a slight shimmy over 60mph
Old Feb 17, 2003 | 10:34 PM
lee2375's Avatar
W212 E63, Audi R8 4.2, Panamera S, Range Rover Sport GT
brabus has changed their manufacturing, so this is a difficult question to answer, but something is wrong.
Did you check for radial runout of the wheel? sometimes a tire is out of round.
Old Feb 18, 2003 | 09:27 PM
Adonis's Avatar
CLK 320
Lee ,
The tire are brand new Kumho 712 235/40f and 255/35r from TireRack.
Old Feb 19, 2003 | 08:27 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
just because they are new it doesn't mean that they can't be out-of-round .... find a shop with a GSP9700 balancer and they will be able to determine if the wheels or tires are causing your problems
Old Feb 19, 2003 | 12:16 PM
E55 KEV's Avatar
Veteran: Air Force
Is Brabus using hub centering rings for Mercedes fitments? That would be odd if they are only Mercedes specific - the wheels should be built only for 66.56mm centers and not require hub rings.
