Will CL55 wheel fit the CLK430?
Old Feb 21, 2003 | 05:41 PM
xyzpl's Avatar
S60R, ML320, W211/E350
Is is a direct replacement or do i need spacers? or does it not fit at all?
Thanks!!
Old Feb 21, 2003 | 07:04 PM
Eurosport's Avatar
monowiper
i think you need spacers and bigger bolts
but i'm not an expert
Old Feb 22, 2003 | 10:37 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
they will not fit correctly ... lug hardware and offset issues
Old Feb 23, 2003 | 07:09 PM
Kerr's Avatar
G500,toyota supra, 67corvette,05 pathfinder
Im running the 19"s off the CL 600..... The wheels came with spacers and longer bolts... I have not had a problem with them.. Just run 235's on the front 245's rub a little... but then again mine has a 1.5" drop.
All in all i love the look... however on some car the Cruise will not work over 70mph.... at leaston mine it will not.
anyway im running 235 front and 265 rear.
here is a like to pictures.
http://community.webshots.com/album/30433619mIIXdedPYk
Old Feb 24, 2003 | 08:33 AM
no problems ????
tire rub and the cruise control doesn't work ... sounds like problems
Old Feb 26, 2003 | 10:25 PM
xyzpl's Avatar
So does that mean there is no way i can make it fit?
Even if I get spacers and different bolt?
By the way what is the offset on the CL55 AMG wheels?
Old Feb 27, 2003 | 10:22 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Kerr, how did you get 14mm lugbolts to fit inside the 12mm holes on your brake rotor? Or are you using the 12mm lugbolts in the 14mm wheel holes which may cause the bolts to loosen up?
Old Feb 27, 2003 | 12:37 PM
we have a winner !!!! you obviously have a good grasp on the hardware issue I mentioned previously
Old Feb 27, 2003 | 12:40 PM
I can make a windshield wiper fit my dog's butt but, that doesn't make it right
12mm bolts have a 12mm radius ball seat
14mm bolts have a 14mm radius ball seat
there are no 12mm bolts with a 14mm radius seat
Old Feb 28, 2003 | 07:40 PM
xyzpl's Avatar
Haha, funny Luke.
So in the end, yes i can make it fit if i REALLY want to, but why would I, right?
Thanks for all the help.
Old Mar 9, 2003 | 10:50 AM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
In the wonderfull world of auto mechanic anything can be accomplished, with a little imagination.
