W211 and W209 wheels interchangable? (Aftermarket)
I'm looking to purchase a set of rims that were on a W211 E55 for my W209 CLK55. I've asked on a couple of different forums but haven't gotten a definitive answer on whether this will work or not so thought I would ask here. Seems like there's many well informed people in this particular sub-forum!
Wheel specs:
Front - 19x8.5 +36
Rear - 19x9.5 +32
I wanted to make sure I won't run into any issues. I've got an 05 CLK55 so it's got the bigger brakes, if that makes a difference.
Thanks all!
Wheel specs:
Front - 19x8.5 +36
Rear - 19x9.5 +32
Thanks all!
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
The rears should be okay. The fronts with possibly the right size tire say a 225/35 "might" work. I have a +32 with a 235/35 that runs very close to the strut. I am sure you will get the info here from someone possibly running this offset. Good luck with it. Mike
What Black7 is referring to the ball radius size on a 209 is r12 and on the other a r14. they could in fact even have a different shank diameter. Sorry I missed that. I was only looking at the offsets. M
Check www.radusadirect.com
