Fuel Consumption Question - Rims - Please look
Old Mar 16, 2003 | 11:50 PM
tradertt's Avatar
Hi, I have a question which I wonder any one with experience could help answer.
If .. IF I have 2 choices of Wheel Rims ..
1) A 15 inch rim that is heavy (8kg)
2) A 16 inch Rim that is light (6kg)
Which will have a higher fuel consumption? I know that it takes effort and of course more fuel to move a rim that is of bigger size ... but with its weight into effect ... will it be offset or even have better fuel consumption than the 15 inch one?
Thank you for this silly question.
Old Mar 17, 2003 | 07:56 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
it's not the diameter of the wheel that will alter fuel consumption it is the weight .... providing your tires are the correct size
Old Mar 17, 2003 | 09:00 AM
tradertt's Avatar
What do you mean by the tire size? What if the overall diameter of the tire increases? Will that cause fuel consumption to go up?
Old Mar 17, 2003 | 04:59 PM
the tire size refers to diameter ....
a taller tire would hurt acceleration and the corresponding gas milage but, once up to speed the RPM's needed to maintain a certain speed would be lower so It would probably even out ... and the exact opposite would be true with a shorter tire
Old Mar 17, 2003 | 11:23 PM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
get the 16". u should get the corresponding tire that'll keep ur overall 14" tire diameter. here's a tire size calculator for an example....plenty of these on the web
Old Mar 18, 2003 | 12:11 AM
pokerFACE's Avatar
on a similar note, which is heavier? alloy or steel of the same size?
