Proper Tire pressure - larger diameter wheels
Old Jan 30, 2010 | 09:53 PM
jimmymac's Avatar
2007 sl550
I have a 2007 SL550. I replaced the original wheels and tires with new, larger ones. The newer tires have shorter sidewalls as well. What tire pressure should I use? Should I go with the car's recommended 30/33psi front/rear, or something else? I already hit a pothole and pinched the sidewall on one of the front tires which I need to replace. Could this be due to tire pressure that was too low?
Original Tires - Michelin Pilot Sport
front 255/40-18
rear 285/35-18
New Tires - Continental Extreme Contact DWS
front 245/35-20
rear 275/30-20
Also, the recommended tire pressure on my gas cap door is 33psi rear and 30psi front. The tires have a max pressure of 51psi listed on the sidewall. Am I correct that I can use any pressure between the Mercedes recommendation and the tire manufacturer's maximum pressure?
Old Jan 30, 2010 | 10:21 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Not necessarily. Its most likely due to the fact that you do not have enough 'meat' on the sidewall. Thats one of the pitfalls with going with a 'rubber band' set up - bigger wheels, shorter sidewall.
Old Feb 1, 2010 | 02:19 PM
COR Forged's Avatar
Former Vendor of MBWorld
Manufacturer
Jimmy,
Try running 38 in the front and 42 in the rear. I have a similar tire set up (245/35/20 295/30/20) and have no problem with anything.
