vogtlandvs eibach springs and with what set of shocks?
Old Jun 2, 2010 | 06:55 PM
bheng's Avatar
2003 CLK 320
hey. i want to know what is the difference between vogtland or eibach springs. i see both advertising a 1.2" drop. i know the vogtland is a tuv approved spring. but thats about it.
i dont really want anything aggressive as i will most likely carry weight in the rear. if i do, i dont want it to rub or want to purchase camber arms to relieve such negative camber that h&rs give.
so please give me your insight on the springs? and what shocks do i get? im torn between koni yellows, fsd, or bilstein HD. keep in mind, i do moderate commuting and no autox. and occasionally have weight(sub+amps) and other ppl in the back.
Old Jun 7, 2010 | 12:57 PM
mint's Avatar
2013 FIAT Abarth 500
I was under the impression that Vogtlands give a more aggressive drop than H&R.
Eibach offers the most moderate drop out of all these options, and get Bilsteins Sports.
Old Jun 7, 2010 | 01:09 PM
bheng's Avatar
2003 CLK 320
i was under that impression too. but a member with the same car said that his only dropped to 1.2" after driving 1300 miles with them. i get a lot of mixed views. but for the CLK, it seems like 1.2"
and you can see it in the pics as well. odd, i know
Old Jun 8, 2010 | 01:02 PM
mint's Avatar
I'm guessing you have a 209?
http://www.vogtlandsuspension.com/p1...duct_info.html
That's for a 209; their website states approx. a 1.4" (35mm) drop on all corners and I believe that's their standard drop for all their MB applications.
http://hrsprings.com/scripts/appguid...ind3&MakeID=25
H&R says 1.4 in the front, 1.3 in the back (though if you have a cab their stated drop is 1.3 in the front, 1.1 in the rear).
http://performance-suspension.eibach...cation_look_up
Eibach has 1.2 on all corners.
I'm still confident that post settling, Vogtlands are slightly lower than H&Rs. You also will want to research ride quality between Vogtlands and H&R--I wouldn't even consider Eibach unless you want a very mild drop.
