Wheel Bolt Size for Spacers Question
Old Aug 6, 2010 | 08:27 AM
jlb0125's Avatar
2010 C350
I am thinking of adding wheel spacers to my 2010 C350 Sport. I have OEM AMG 17 x7.5 ET 47 fronts, and 17 x 8.5 ET 58 rears. Now, if I do 3mm front spacers, then I will need 50mm wheel bolts for the front, no problem. If I do 5mm rears, then I would need 63mm for the rear, but there isn't a 63mm wheel bolt that I can find, closest thing is 65mm. So the question is, will 65mm be too long?
Old Aug 8, 2010 | 01:10 PM
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
What you need to do is find out what the stock OEM lug bolt length is. The wheel offset has nothing to do with the bolt length. The bolt seats in the wheel. This depth can differ from one style of wheel to another. Call or email the site below. They are very knowledgeable people and can give you the info your seeking. My stock wheels on my 06 CLK were 39mm. My aftermarket wheels take a 27mm. I run a 15mm spacer at the rear and had to increase my lug length to a 45mm which I purchased from RAD USA. Mike
www.radusadirect.com
