Question about sidewall...
Old Aug 19, 2010 | 11:32 AM
JamE55's Avatar
Out Of Control!
The wider you go on tire size, the taller the sidewall is? Is this correct? And vice versa? Just need clarification.
Old Aug 19, 2010 | 01:27 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
255/35-18
255 x .35 = 89.25mm (sidewall weight)
275/35-18
275 x .35 = 96.25mm (sidewall height)
so, yes a wider tire with the same aspect ratio will be taller
Old Aug 19, 2010 | 06:54 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Nope. It all depends on the aspect ratio.
Old Aug 27, 2010 | 08:13 PM
rmfnla's Avatar
2013 Infiniti G37 Coupe; 2011 GLK 350 w/ Premium 1, Multimedia & Sport Appearance; I LOVE IT!
Are you talking about aspect ratio or just width?
You can swap your wheels I tired for some an inch or two wider and it will not affect the sidewalls at all.
