Front Inside Edge wear on 2007 E63
Old Mar 30, 2011 | 10:08 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
OK Luke, I have 70kmiles on my E63 and I have been buying new tired from you guys every 12K miles, plus my Hankook R-s3s. So I am looking for some help.
If you do not want to do this on the open forum, PM me and I will close the thread.
This is the second set of Goodyear Eagle F1 Asymetrics which have been wearing like this. This set included a 4 wheel alignment at Performance Arts in Gilroy, CA who are know for doing good work. They had my caster bolts in stock in fact.
Here I am at about 12.5K miles and this is what I have on the fronts. The inside edge weare is nuts!
I would really like to get 25K out of the fronts. The rears go in 12-14k, and I know the reason for that.
Is this a toe or caster problem?
Thanks in advance.
Jon.E63.AMG@*.* (so you can look me up in your system).
Old Mar 31, 2011 | 09:57 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
that type of wear is typically a combination of camber and toe out ... do you have the print out of the alignment angles after the alignment was done?
Old Mar 31, 2011 | 01:11 PM
jaedee's Avatar
w205 C63s, w212 E63,w219CLS500-SOLD! w211 E63, 2006 E60 M5 (KABOOM!)
I have the same issue with my front tires.
Old Mar 31, 2011 | 01:33 PM
Jasoneo5's Avatar
W211 E55
Check your ball joints and thrust arm bushings. 70k is probably enough miles for them to have gone bad. Mine went around 80-90k
Old Mar 31, 2011 | 11:14 PM
I have the results on the alignment. I need to find them and then will post.
Thanks for the reply Luke. Piurists would say positive toe and negative toe, but given your normal audience, I gotcha.
Also, thanks for the heads up on the ball joints. I will check them
