New E Brake Noise--luke Help
HEY LUKE I NEED UR HELP ON THIS ONE.
Is there anything thats need to be changed with the sbc brakes, because i get a buzzing noise and vibratoin somtimes, when i turn the steering wheel full, and turn off and turn on the car. IS THIS NORMAL!
HELP!
THANKS
HELP!
THANKS
TR Moderator & Tire God
depends on the weather
it sounds like you have an ABS pump issue ... which is common when installing new pads because you have forced some brake fluid back through the system by pushing the pistons in .... it is a very minor issue which should go away shortly
