Difference between Authentic LM5 & LM5 Replicas
Old Aug 3, 2003 | 12:05 AM
clk_klass's Avatar
02 clk320
Where can I get these rims (Zauber Gettin)for less $3000?
this guy quote me for $850 each, polish
Old Aug 3, 2003 | 03:10 AM
KenjiTsou's Avatar
1998 E430, 1993 LS400
Re: Where can I get these rims (Zauber Gettin)for less $3000?
PM me the size and offset you want and I can get the wheels for you
Old Aug 7, 2003 | 05:52 PM
triniblack's Avatar
E 420
Thumbs up zauber gettin rims
Originally posted by KenjiTsou
One more....
Those rims are hot to death. Is there a web sight for that company? How much do they cost? beautiful rims dude.
Old Feb 2, 2006 | 09:17 PM
Adimax382's Avatar
'02 CLK430
Thumbs down !!!!!!!help!!!!!!!
What up guys,
My name is Omid and I own an '02 CLK430. I recently purchased the Lorinser LM5 style wheels 19x8.5 with 235/45ZR19 tires. I have yet to put them on however. I was just wondering if I should get spacers or if I should just cut my bolts shorter. I was told I could do either or, however wanted to take the correct route instead of just guessing. The wheel states it has an offset of ET38.... so if I were to get spacers, what size do you recommend? I think the rear wheels will be fine, but i might need spacers for the front ?? Any feedback would be greatly appreciated!!!! Thanks guys!
Old Feb 3, 2006 | 11:40 AM
Benzoxtc's Avatar
2002 CLK 430/2002 325i
The authentic LM5 wheels come with a 7mm spacer, which will yield an ET31. Without the spacer the wheel has ET38.
Old Feb 3, 2006 | 04:00 PM
Ken Uyeda's Avatar
Collections Ban
Lorinser
Authentic Lorinser LM-5 wheels will all be ET38 and have "Made in Germany" and "RONAL for Lorinser" on the back of the wheel as part of the cast. They are all a 2-piece design with titanium rivets that have "RO TITAN" stamped on the rivet heads. The wheels have a centerbore of 82mm. This is to accomodate the various TUV approved mounting kits which include either a center ring or a hubcentric spacer that locks into the wheel as well as the appropriate length lug bolts. These mounting kits are included with the purchase of a set of Lorinser wheels.
For an `02 CLK, the mounting kit you need is 433 4000 00 which includes a 7mm huncentric Lorinser spacer and the appropriate length 12x1.5 lug bolts. Wheel lock kit 434 4000 00 is also available with locking lugs of the correct length. Tire sizing on your CLK should be 235/35R19 all around, or 235/35R19 Front and 265/30R19 Rear if you are running the 19x8.5 & 19x9.5 staggered set up.
Originally Posted by Adimax382
What up guys,
Attached Thumbnails Difference between Authentic LM5 & LM5 Replicas-dsc01559.jpg   Difference between Authentic LM5 & LM5 Replicas-dsc01560.jpg   Difference between Authentic LM5 & LM5 Replicas-dsc01561.jpg   Difference between Authentic LM5 & LM5 Replicas-dsc01562.jpg   Difference between Authentic LM5 & LM5 Replicas-dsc01563.jpg
Old Feb 6, 2006 | 08:03 AM
  #32
Adimax382's Avatar
'02 CLK430
replicas??
will i need a 7mm spacer if i have the replicas ?? is this just for the front wheels or would i need spacers for all 4 wheels??
Old Feb 6, 2006 | 08:31 AM
  #33
Adimax382's Avatar
'02 CLK430
last question i swear.........
does anyone know where i could purchase this 433 4000 00 mounting kit ?? ive tried searching everywhere on the internet and seem to be going no where fast. im assuming the kit also includes lugnuts and bolts too?? thanks guys...........
Old Feb 6, 2006 | 08:58 AM
  #34
BklynBenz's Avatar
CL500
the kit can be purchased from cec (www.cecwheels.com) and i believe its $100 for each wheel which includes the spacer and lugs. i had a problem and i needed new lugs all around so i was forced to buy 4 of these kits a few years back and had no use for the additional spacers. i looked around but all i could find now was 3 of the 7mm spacers. heres what they look like:
let me know if you want them.
Old Feb 6, 2006 | 12:19 PM
  #35
Ken Uyeda's Avatar
Collections Ban
Lorinser
Lorinser in Northern Virginia
For purchasing information on Lorinser products for Northern Virginia, please contact Dealer Direct Services who is the Lorinser distributor for the Northeast. Contact: Mike Arner (800) 334-6074. Note that this mounting kit is designed to work with the authentic Lorinser LM5 wheels. They will most likely not fit into a replica wheel. Each Lorinser mounting kit will include the appropriate length lug bolts as well.
Old Feb 11, 2006 | 04:17 AM
  #36
Adimax382's Avatar
'02 CLK430
Unhappy
ANYBODY SOMEBODY ANYBODY SOMEBODY ANYBODY
I took my car to have all 4 wheels and tires put on and it was a DISASTER ! I took them to my local Mercedes Benz dealership here in the DC area to have them "professionally" installed while I took my baby in for its Service "A". I figured, why not have them just fix em up for me, since they afterall will know the specs and everything, and i could be rest assured that they will be responsible if its not moutned right.......
WELL.... believe it or not, they installed all 4 and they looked beautiful.
HOWEVER... on the way home both of my front tires went flat because they were rubbing ! WHAT IDOTS !!!!!!!!!!
To make a long story short, they paid for the towing, had my old wheels and tires put back on, and provided me a rental car during this whole mess. They apologized and simply stated that the vehicle needed spacers and they could not assist me any further.
SOMEBODY PLEASE HELP ME! I KNOW SOMEONE HERE CAN TELL ME WHAT specs OUR WHEELS HAVE and CAN EXPLAIN WHAT et38 means on these lorinser replicas i have!!
better yet..... someone just tell me what mm spacers i need and ill do it myself!!!!!!!
HHHHHHHHEEEEEEEEELLLLLLLLPPPPPPPPPPPPPPPP !
Old Feb 11, 2006 | 12:32 PM
  #37
Ben'z's Avatar
E320
I am sorry to hear your story.
ET38 offset sounds right, how wide are your wheels? what is the size?
Old Feb 11, 2006 | 01:15 PM
  #38
Vader55's Avatar
AMG E55, Stage 1, Strait Pipe from Primary Cats
Originally Posted by KenjiTsou
I wouldn't say German makes better wheel than Japanese. Japanese wheels have great building qualities and finishes. Brabus, Lorinser, Hamann. Hartge, AMG, Carlsson.....etc They are all nice wheels.......But you are just paying for the German or European brand. For example, Brabus Monoblock V in chrome is list at $1750,and I don't think Brabus really worth that much. With that price tag, I would go out there and get myself a set of forged Fabulous Profound.
Bravo my friend !
The strongest and lightest wheels are: Forged,Pressure cast and Poured cast
The bottom line is when is comes to a cast wheel, The pressure cast wheels are lighter and stronger than poured cast wheels which is how the list you gave above are made, The poured cast wheels are very heavy. My buddy used to drill out wheels for Brabus and when he would hit a air pocket in the cast it would make a pop sound. This is one of the reasons why the pressure cast is stronger and superior(no air pockets due to pressure cast) and I would expect to see the trend moving this way. Asia is leading the way on this.
