18" wheel weights and size.
Old Feb 28, 2002 | 03:24 PM
JustinTRW's Avatar
C32 AMG
I'm thinking to upgrade to 18" wheels from the 17" that will come with my C32 AMG. What would be the best tire size to go with?
Also, I want to minimize unsprung weight if possible. Where can I find information on the weight of stock wheels versus that of aftermarket or other AMG wheels.
Old Feb 28, 2002 | 06:33 PM
Harris's Avatar
If you dont want to do any bodywork modifications to your car, then the best tire combination for staggered is 225/40/18 and 255/35/18. If you dont want staggered, then it'll be 235/40/18.
Agree Wheelexperts.com?
Old Feb 28, 2002 | 06:45 PM
lee2375's Avatar
W212 E63, Audi R8 4.2, Panamera S, Range Rover Sport GT
You are absolutely correct, sir.
Old Mar 1, 2002 | 02:53 PM
E55MKB's Avatar
96 P993T, 00 E55, 09 SL63
Wheel and tire weight
Here are some weight data for E55 fitment (just for comparison)
18" AMG monoblock 18x8 ET31 27.5lb (cast)
18" AMG monoblock 18x9 ET35 28.6lb
18" OZ Superleggera 18x8 18lb
18" OZ Superleggera 18x9 19lb
18" Renntech 18x8.5 20.8lb (cold forged)
18" Renntech 18x9.5 21.2lb
18" Fikse FM5 18x8.5 22lb (forged center)
18" Fikse FM5 18x9.5 23lb
18" SSR Intergral 18x8 19lb (semi-solid forged)
18" SSR Intergral 18x9 20lb
I do not put in Brabus or Lorinser weight since your aim is to lower unsprung weight. Brabus and Lorinser would be heavier than the AMG wheels (low 30s lb)
Tire size 245/40-18:
Michelin Pilot Sport 25.0lb
Bridgestone S-03 27.5lb
Toyo T1-S 24.0
Dunlop SP9000 26.5
Yokohama AVS db 25.1
Yokohama AVS Sport 25.3
Tire size 275/35-18:
Michelin Pilot Sport 27.0lb
Bridgestone S-03 29.0lb
Toyo T1-S 25.6
Dunlop SP9000 27.1
Yokohama AVS db 27.3
Yokohama AVS Sport 28.0
You can see that S03s are relatively heavy tires
Hope this info help
Old Mar 2, 2002 | 12:04 AM
JustinTRW's Avatar
C32 AMG
Thanks. You all have been very helpful.
Justin.
Old Sep 2, 2002 | 09:20 PM
C32TOM
Guest
Posts: n/a
Hello,
Like JustinTRW I'm going to upgrade my C32 wheels to 18's. Does anyone have weight data on the Brabus Monoblock VI 2-piece. I'm considering:
8.5 x 18 Front
9.5 x 18 Rear
Will the new wheels influence the performance of my vehicle? If so, how? Thanks is advance guys!
Tomaso.
Old Sep 3, 2002 | 01:05 PM
Harris's Avatar
19" weighs about 32lbs each. I would assume 18" will be 2-3 lbs less? It will, obviously, slow your car down a bit during acceleration, but I think the C32 power can overcome that!!
