19" wheels on a 2000 E430 4Matic
Old Aug 26, 2003 | 06:02 PM
mischief's Avatar
W205 AMG
I'm looking at getting a set of 19" wheels for my 2000 E430 4Matic. The fronts would be 8.5" wide and the rears would be 10" wide. What size tire should I run? Thanks.
Old Aug 26, 2003 | 07:26 PM
Harris's Avatar
1) Are you sure you want to put 19's on a AWD car?
2) Are you sure you want to put staggered setup?
If your answer is yes to both questions, I thnink you can put 245/35/19 and 275/35/19.
However, I wont suggest this upgrade.
Old Aug 26, 2003 | 08:50 PM
mischief's Avatar
W205 AMG
why don't you suggest I run those 19s one the E430 4matic?
Old Aug 27, 2003 | 01:17 AM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
yes, why not a staggered setup?
will it throw off the ABS/ESP? rear wheels getting more traction than the fronts?
Old Aug 27, 2003 | 09:01 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
19's will work but, a staggerd setup is a bad idea because of the all-wheel drive system ..... the MB system is a viscous coupled system which will be adversely affected by a wider wheel/tire in the rear
Old Aug 27, 2003 | 09:37 AM
theboogers's Avatar
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
i have some renntech 9 x 19 w/ new michelin pilot sports mounted. i have $3500.00 invested if you are interested. email me at igrd@erols.com, thanks
Old Aug 27, 2003 | 10:17 AM
mischief's Avatar
W205 AMG
Luke, can a 245 35 R19 tire fit on a 19"x10" rim?
