wheel balancing / shake
Hi
I have a 2000 model C320. When I get to around 60 mph up to 70 there is a shake coming through the steering wheel. I had the front wheels re-balanced and since then, I have had the back ones checked as well and it did seem to help. I then had 2 new tyres fitted to the front, which were of course balanced at the time but I am still experiencing a shake through the wheel at the above speeds.
Above and below these speeds it is unoticble ( as far as I can tell ) , but it ruins the feel of the car. It is also more noticible when you are carrying passengers.
I was going to get the front wheels re-balanced ( not a the same garage that fitted the new tyres ) to get them checked but if this fails, does anyone have any idea what else could be causing this. Also,when I brake there is no vibration, shake, pulling etc.. from normal braking, so that is OK !
UPDATE : Front wheels have been re-balanced, much better but ther is still a noticble shake at 0 - 65 mph. Any ideas !!
Jason
Is there a Hunter GSP 9700 balancing system available over yonder?
See: http://128.242.141.111/pub/features/how.cfm
Get yee to a shop that has this system, and if the tech is worth his salt, your problem will be found and it is correctible.
End of story. Good luck.
Please keep us posted.
John
