Spacer question for Luke,
Old Sep 14, 2003 | 11:52 PM
heeman's Avatar
CLK 230 Kompressor
Dear Luke
Old Sep 14, 2003 | 11:59 PM
heeman's Avatar
CLK 230 Kompressor
Sorry, accidentally sent out the post before typing in the question.
For some reason on my w208, the right rear wheel is more recessed into the wheel well than the left. I assume the offset is the same for both rear wheels.
I am using 12 mm spacers on both sides but there is a visible difference between the 2 sides.
My question is can I use a wider spacer on the right to match the left? I estimate the difference to be 5 mm.
Thanks in advance.
Old Sep 15, 2003 | 11:13 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
you really should find out the reason for the difference rather than just trying to hide it ...... there could be something structurally wrong with your car ...... have it checked out
