20" wheels/tires help
Old Nov 20, 2003 | 01:14 PM
ArMaNi S500's Avatar
2000 Mercedes S500
What's up guys. I just received my tires for the rims which should be here tuesday. i went with the michelin pilot sport ps2 (2nd edition pilot sports) the tire size I went with was 255/35/20. The rims are chrome Lowenhart LD1s 9" wide all around. After driving for about 5 years and going through 4 different cars, this is the first time I bought custom wheels for my car. Sadly enough the biggest wheels I've ever driven on are 16" and those are my current stocks.
I was hoping to get help with anything I might need to know that is now different from driving on stock wheels. As far as the tire pressure, do I keep it the same as what is suggested on the Gas tank lid? Is it true my speedometer won't be as accurate anymore? The tires I bought claim to be summer tires, does anyone think that was a bad decision considering I live on Long Island, NY? Any other advice would be greatly appreciated. Thanks.
Old Nov 20, 2003 | 01:16 PM
2000 Mercedes S500
btw, they're said to be max performance summer tires
Old Nov 20, 2003 | 01:49 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
DO NOT DRIVE THE CAR IN ANY COLD PRECIPITATION
Old Nov 20, 2003 | 02:29 PM
2000 Mercedes S500
really? are you referring to snow only? do you think these are good tires? what do i do about tire pressure? thanks
Old Nov 20, 2003 | 09:02 PM
Junbug's Avatar
2004 C230W
Max Summer
1) You might want to keep the tires in your garage until next spring as we're gonna get some snow in 4-6 weeks (I hope not).
2) Try to avoid any and all potholes / creases in the road as you'll have less side walls to soak up the shock.
3) Make sure you have the correct tire pressure at all times, especially at times when there could be sudden temp changes (like in spring and fall).
I am sure I can keep on going. I hope you like the ride of your 20's. I personally would have a hard time going from 16's to 20's.
Old Nov 20, 2003 | 09:24 PM
2000 Mercedes S500
Thanks for the reply. I have a 97 explorer so I'd drive that if it were to snow. But wouldn't I be able to drive until we receive that first inch+ of snow?
Also, as for keeping the tire pressure the same. Do I keep it the same as what MB says on the gas lid? Or is it different now that I have low profiles?
As for the jump from 16" --> 20", I know it might take some adjusting, but to be honest my friend's got an 840ci with 19"s and my other friend has a GS400 with 20"s and the ride doesn't seem harsh at all. Plus because of the airmatic suspension, I think the ride should still be somewhat comfortable considering Mercedes tuners such as Lorinser and Brabus even put 20" wheels on their modified cars.
Old Nov 20, 2003 | 09:37 PM
Kar don's Avatar
Mercedes-Benz
it wont be too bad but do not expect the butter smooth ride of those all season 16 inch tires. The PS2 is def a good tire tho.
Old Nov 21, 2003 | 10:23 PM
2000 Mercedes S500
does anyone know if it's ok for me to drive on the pilot sport 2nd eidtions (PS2) in the winter, but NOT in the snow? I was looking to drive on these tires on dry/wet pavements all year round except when there is snow.
Also, has anyone had any experience putting 20" wheels on a w220 s class? Do I just simply put them on or do I have to worry about rolling the fenders or rubbing? Thanks
Old Nov 22, 2003 | 12:07 AM
Frisco's Avatar
03 CLK500, 04 X3, No 07 GT3RS :(
I thought the S took 9.5x20 with 245/35f and 275/30r?
Old Nov 22, 2003 | 02:05 AM
2000 Mercedes S500
the lowenhart ld1's are 20x9" all around so i chose 255/35/20 as my size
Old Nov 22, 2003 | 07:37 AM
Harris's Avatar
From what I heard from my NY customers, the roads are pretty bad there. Therefore, they wouldnt even want to put 19" on the car. So if you have 20", be EXTRA careful. I think there is a much higher chance for you to bend the wheels. Not to mention 20" tires are VERY expensive to replace.
Your tire pressure should be around 40psi, since you dont have much rubber, I dont think its a good idea to have low pressure as your wheels will, again, be bent more easily.
I would say the ride should be "acceptable-ly" rough. When Luke was saying dont drive the car in cold precipitation, I guess he meant snow/flurries/snow rain. Normal raining condition should be ok.
Old Nov 22, 2003 | 07:28 PM
Junbug's Avatar
2004 C230W
I remember Luke posting something about losing traction and experiencing faster wear with summer tires once it gets below 40 degrees. I guess the compound is really not meant for colder weathers.
Old Nov 22, 2003 | 09:24 PM
2000 Mercedes S500
Thanks for the info junbug, that was a great help. So i don't understand how summer tires lose tread quicker in lower temperatures? I don't remember what state the person was in, but I'm pretty sure I read a review of these tires on tirerack.com and the owner said he's had the tires for 37k so far and still going. If I could get about 40,000 miles out of these tires I would be satisfied. I'm now beginning to regret getting the PS2's and thinking I should've gone with a set of the Pilot Sport A/S's. The only reason I went with these is because of the improvement it claims to have acquired as the newer/better? version of the original Pilot Sports.
FYI, I bought brand new 20" 255/35/20 Michelin Pilot Sport PS2 tires shipped to my home for a price of $650. This is ridiculousy cheap and I had my doubts so I bought them from a private seller by COD. Does anyone have any idea how I was able to obtain the tires at such a cheap price? Is it possible that tirerack.com marks up their tires 150%? Thanks
PS chances are I could always get the Pilot Sport All Seasons for the same price and just sell these. Does anyone highly recommend that I do so or should I just stick with the tires that I have already?
