running 17's on clk 320 my spare is 16 is this a problem?
Old Jan 27, 2004 | 12:00 PM
ttagent's Avatar
clk 320 2002
Old Jan 27, 2004 | 04:49 PM
Steve Clark's Avatar
C32AMG
Problem?maybe!
How much do the 17" and 16" tires vary in diameter?.If there's less than 1/4" difference,there should be no problem.Any more,and I would be sure to use the spare on the front only.If you have a rear tire go flat,play musical tires until the spare is on the front and two original tires on the rear axle.
Sound like a lot of work?.It's a minor pain,but better than what you'll do to the differential if the tires don't have the same diameter on the rear and you go flying down the road.
BTW-if you hurt the diff this way,warranty won't cover it.Take care to use the proper wheel-bolt length-I'll bet your 17's use a longer bolt than the 16" spare does.
Old Jan 28, 2004 | 02:31 PM
ttagent's Avatar
clk 320 2002
What size spare do clk430 come with?
Wht size spare tire do clk430's (old body) come with if they come stock with 17" staggered setup?
Old Jan 29, 2004 | 02:38 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
providing that all of the tires including the spare have a 25" diameter you will not havve a problem ....
Old Jan 29, 2004 | 05:42 PM
ttagent's Avatar
clk 320 2002
thanks going to go measure!
