Coil over question?
I am planning to buy KW coil over either variant 1 or 2.
Since variant 2 is more expensive due to the rebound adjustment
capability, does it worth the extra buckss ?
what do you guys think? if I just want to lower my car does variant 1 should be enough?
xquisit
even better, go and get the kw variant 3
yeah...if u get coilovers, then u should probably get one that has not only adjustable height, but the rebound adjustment as well...just about as expensive...u could save a bundle if u simply wanna lower the car by just getting a simple lowering spring
I agree with everybody else.
But Variant 3 does not have any Mercedes application.
but I still dont quiet get the idea of the benefit having adjustable rebound? what is rebound for? and what about dampening setting what is it? I am kinda a newbie in this area :P
and harris is PSS 9 has same options as KW variant 2 or 3
thx again
anyway....getting the right suspension setting for ur taste and ur butt is not always easy... having the rebound adjustment allows u to have a bit of control over that...
rebound adjustment is the adjustment in how well a shock dampens the movement when it is being extended... compression is when the springs are compressed, and rebound is when the springs extend back... rebound adjustment affects the car's characteristics the most.... so many offer rebound adjustments... koni sport shocks are rebound adjustable for example, as are the kw v2 u mentioned... most start with rebound adjustments, then compressions adjustments...
for example...if ur car feels loose and has a tendency to bounce excessively like a car with old worn out shocks, then u need to have more rebound dampening... if ur car starts to feel hard and bumpy, espeically in a really lousy section of the road...then u need to soften up the rebound dampening...
next, for compression, if u car feels like the quintessential boat...where ur car feels floaty and bottoms out easily, then u need more compression dampening... if u car is harsh and doesn't provide a lot of give when going turn bumps, then there's too much compression dampening...
that's too bad...no v3...
if that is the case then I think I will go for the v2, because having an options is better than not having one
