2001 CLK55 and E55 same wheel fitment?
Old Mar 10, 2004 | 11:21 PM
sajecw's Avatar
I have a set of 19" HRE 448's 19X8.5 and 19X10 on a 2001 CLK55.
Will they fit on a 2001 E55?
I tried putting a set of SSR GT3's from my CLK on an E55 and the rear bore size of the hub on the E55 was too big.
Anyone know before I have this guy drive to my house?
Old Mar 11, 2004 | 03:10 AM
Harris's Avatar
Oh Chris, I thought you're saying the new E55!!
Your wheels will fit the W210 E55. Not a problem.
Old Mar 11, 2004 | 08:16 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
w210 E55 wheel fitment is basically the same as the w205 CLK55
Old Mar 16, 2004 | 02:08 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
The wheels may fit, but you may have a problem using the U.S. OEM W210 E55 front tires of 245/40/18. If the offset pushes the tire inward more than 4mm it may rub with certain broad shouldered tires. If that happens you may need to use a 235/40/18 up front.
I changed front from 18X8 et31 to 18X8 et35 and could not use Nitto 555 and the Dunlop 9000 rubs on occasions depending on suspension compression and uneven road surface, etc.
E55 KEV's Avatar
Veteran: Air Force
Old Mar 16, 2004 | 02:09 PM
E55 KEV's Avatar
Veteran: Air Force
