They make an epoxy based kit specifically for calipers that resist heat and brake fluid which will destroy normal car paint. You can DIY or have them do it, I think it's called a G6 kit available on amazon or even locally at wal-mart or any auto parts store. Changing out your brake system is expensive. You may also want to consider your calipers may not be the full type as in a big brake kit since you have a 350, it may be the simpler open type where you can see the back of the brake pad and those don't have the same look as the closed type which sounds like what you're after perhaps. They probably also mean your PADS are ceramic not your calipers FYI- and painting the back of the textured brake pads with the open calipers looks awful anyway IMO (plus when you change pads the color is gone too).
