Luke, help
Old Apr 15, 2004 | 09:05 AM
888c240's Avatar
Question Luke, help
Recently I changed my stock wheels/tire from 205 55/16 to 225 40/18 and I noticed that on the side wall it says 44PSI. I dont drive it everyday, may be on the weekend with dry sunny day. Should I keep it 44PSI or is it too much??
Old Apr 15, 2004 | 10:29 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
44 is the maximum pressure for the tire and it is not what you should be running unless you want a really stiff ride ..... the pressure recommendation for you car can be found under the gas door
Old Apr 15, 2004 | 10:49 AM
888c240's Avatar
If I used the recommand PSI for the new 18" wheels and with 225 40/18, would it demaged the wheels if I do a sharp turn without slowing down cause it looks flat at the bottom if I put in ~32,34 PSI??
Old Apr 15, 2004 | 02:22 PM
no you wouldn't damage the wheel at recommended pressure but you can always add more air .... 44 psi is just really harsh riding
