Wheel spacers for c-coupe
Old Apr 10, 2002 | 08:47 AM
avlis's Avatar
2008 VW GTI
I have the C7 wheel package and was wondering if anyone tried putting spacers behind the rear wheels on the coupe. They seem to set a bit too far IN for my taste. I'm thinking that a 1/2" spacer might do the trick. Thoughts?
Old Apr 10, 2002 | 11:28 AM
KWiK's Avatar
2002 C230 : 2007 C230
I have been using H&R spacers (20mm) on the rear for over 6K miles. Looks much better.
Old Apr 10, 2002 | 03:26 PM
avlis's Avatar
2008 VW GTI
Ouch- $95 a pair! I might just get some made myself. Are they just simple hub-centric spacers?
Does the kit at least come with longer lug bolts?
Kwik, you have no clearance issues with 20mm and C7 wheels? I did some quick measurements the other day and it looked like 20mm (or 3/4" for that matter) would cause the tire to come too close to the fender lip under compression? Perhaps the suspension moves in a nice enough arc to clear.
Got any pictures?
Old Apr 11, 2002 | 11:41 AM
KWiK's Avatar
Originally posted by avlis
... Are they just simple hub-centric spacers?
Yes & No. They are hub-centric, but I wouldn't trust just any shop to make a set.
No, but you can get them at Prestige Wheel
Kwik, you have no clearance issues with 20mm and C7 wheels?...
None, they clear just fine.
Got any pictures?
I will try to take some this weekend.
Old Apr 11, 2002 | 02:33 PM
avlis's Avatar
2008 VW GTI
Can you give me the part number or dimensions (length, dia, seat type) of the lug bolts you got? I thought they were 12mm cone seat but, just making sure.
Old Apr 12, 2002 | 11:05 AM
KWiK's Avatar
Got any pictures?
This is the only one I could dig up. This is with the 20mm spacers installed.
