My rotor screws!
When I changed out my right front rotor, I accidentely over torqued my rotor screw so the screw broke off.
Tried to drilled out that thing, But it was just too hard. So when I mounted the Disc, I just have to use couple of lug bolts to hold the rotor inplace then mounted the pads.My question is what is the purpose of the rotor screw? Is that just used in the assembly line to hold that in place? because I don't think is necessary to have that since we have 5 lug bolts to hold the disc tight. any inputs? any of you guys have rotor screw broke off and left it out?
thanks.
I work on my other cars, but I have yet to have the guts to experiment with my W210. I am afraid I may touch something and the freakin ECU resets itself and won't start the damn thing...
Took a mechanic course a while back.. you probably know about this, but anyway, the instructor kept on referring to MB and how it is a ***** to work on ... certain parts are hard to get to, you may need to take down entire assembly of parts to get to one little thing as well, you have to be very careful in the torque spec.. otherwise anything too tight may break it.
oh, well, I guess I just have to live with the broken screw in it.
I broke one off too, but maybe my thread were clean... Even though the hole is countersunk, the once I took the rotor off, I was able to grab the broken piece with somce diagonal wire cutter pliers. The sharp edges were enough to back out the broken piece. Otherwise, the drill and "easy out" tap will work. You can get "easy out" taps at Sears for sure, but I saw them at the Autozone too.
So Now I just left the broken screw in there any way we don't really need that screw.
This happened to both screws on my son's 91 LS400. I went to Checkers and got a kit (forgot the name) that has 5 bit-like (different sizes). I drilled each screw and pound the appropriate ly sized bit into the screw, used a vice to grab hold the bit tightly and unscrewd the screw out. Easy !!!
Good luck
VH
Hi,
Good luck
VH
Interestingly, the only answer from ebc is that their products are made to fit/specs. I like the rotors, and have obviously used them without the alignment screw.
