Does anyone know the rule on how many turns the lug should turn before it's secure?
Old Sep 10, 2004 | 05:27 PM
trbo2nr's Avatar
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
Question Does anyone know the rule on how many turns the lug should turn before it's secure?
On my GTI VW it turns 8.5x before it's tight but on the Benz it's like 6.5x. Is
there a rule to how many turns is good (other than when it appears to be tight).
This is one of those things I really never know and thought I'd ask (mainly due
to spacers, non OEM rims etc). Thanks guys.
Old Sep 15, 2004 | 07:48 PM
tonewheel's Avatar
Torque wrench, per your owner's manual specs.
Old Sep 15, 2004 | 11:08 PM
pointman's Avatar
a car that can't do the throttle reset.
AT LEAST 6 revolutions... AT LEAST. shoot for 8 or better.
Old Sep 16, 2004 | 11:15 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
minmum is 6 full turns of engagement
Old Sep 16, 2004 | 03:04 PM
meanie's Avatar
Yeah, and when you drive away, your parking brake will be destroyed.
Old Sep 16, 2004 | 03:30 PM
pointman's Avatar
okay, then shoot for 4 or less. :v
Old Sep 17, 2004 | 07:26 PM
430's Avatar
430
SLK32
Be safe and go for at least 18.
Old Sep 17, 2004 | 07:55 PM
pointman's Avatar
did i say four or less? i meant 2 and a piece of chewing gum. :v
Old Sep 18, 2004 | 03:37 AM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
all stuff aside.. u should really get a torque wrench and find out what the torque is supposed to be for ur wheel bolts.
Old Sep 24, 2004 | 04:56 PM
KarToyz's Avatar
05 SLK350, 06 ML350
5.5 turns for 12mm lugs
7 turns for 14mm lugs
Old Sep 29, 2004 | 08:46 PM
dlynch's Avatar
not enough and your lug bolts fall out; lose enough you lose a wheel.
too much and you can warp your rotors. I've done it on a Volvo. Bought a torque wrench after that. should have bought it before.
watch out for hub centric spacer rings. found out the hard way that you need to remove them when you remove a rim that uses them...
DAve L
Old Sep 30, 2004 | 11:27 AM
meanie's Avatar
Pass that on to all the people that NEED to know.
Old Feb 2, 2009 | 03:55 PM
Sincity's Avatar
Subscribed. Good info to know.
Old Feb 2, 2009 | 04:02 PM
link to more info
Old Feb 9, 2009 | 03:47 PM
SickSpeedMonte's Avatar
2007 C230 and 1985 Monte SS
the depth of the threads engaging should be equal to or more than the diameter of the bolt... so for a 1/2-20 lug, you'd want 1/2" of thread engaged, so 6 revolutions or more. Lug bolts have the added consideration of possibly going in too far, but that is the rule of thumb that I have always gone by with studs and lugnuts.
