Measure Ride Height
Old Nov 3, 2021 | 08:42 AM
Mmr1's Avatar
2013 glk 350
Measure Ride Height
13 Glk 350 67000 miles . I’m getting new struts, I want to measure the ride height to see if I need new springs. 8.2” is how much off the ground the manual says it should be . Where do I measure this from, the Rocker Panel?
Old Nov 6, 2021 | 09:17 AM
streborx's Avatar
Top Answer: 1
G550
Ground clearance is supposed to be measured to the lowest surface, so that could be the rockers, or maybe the skid plate or diffrential. Seems unusual you need new shocks after only 67K miles (unless this is elective surgery). The shop doing the work should be able to do a compression test on the springs to see if they're still wihin spec.
Old Nov 6, 2021 | 01:18 PM
Mmr1's Avatar
2013 glk 350
I replaced upper and lower control arms and something is still real loose so I’m just replacing everything, nothing is visibly loose but I can’t stand it. I’m keeping the old springs if it measures close , I’m sure it will. The roads I drive are crap city roads .
