offset and PCD for 20inch rims on C240?
Old May 16, 2002 | 08:52 PM
Accordingly's Avatar
As the title says dose anyone have info on fitting 20inch rims to a C240?
I also need the PCD and offset required to use 20's.
Any info is good info,
cheers peps.
Old May 26, 2002 | 12:54 PM
Tezta's Avatar
CLS350
Negative! 20's are close to impossible to fit on a C. Maybe if you find a 20x 8" rim for all fours, then the tires, then I wonder how the car will drive. It will feel like its on stilts probably. Go with 19's max. They look big on C's anyways.
Old Jun 1, 2002 | 05:04 PM
E_Corleone's Avatar
2001 Silver C320
20's will not fit on a new C. Even if they would, your car would run slower because of 240's smaller engine. 19's are even pushing it for your car. If you want big rims like that, you should have bought the 320 or use your rim money to tune your engine before you get rims. That way you get a faster car that looks tight and runs good.
Old Mar 8, 2010 | 09:10 PM
felipejara's Avatar
C 240
Thumbs up
What about the PCD and offset for putting 19s on a mercedes c240 2002? Also what are the disadvantages for putting low profile wheels on your car? Im new at this kind of stuff so any help is appreciated.
Old Mar 8, 2010 | 10:02 PM
tusabes's Avatar
Mercedes
BS of course 20s will fit. they make skinny 20s these days that will even fit Honda Civics.
Old Mar 9, 2010 | 09:31 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
but the tires in the correct diameter do not have the proper load capacity
Old Sep 3, 2010 | 10:25 PM
MrC.240's Avatar
2003 C240
I got 20's on my C240... running a 20x8.5 in the front and a 20x10 in the rear... 225/30/20 in the front and 275/30/20 in the rear car rides the same but you will pop tires like crazy but it looks soooo good
Old Sep 9, 2010 | 04:20 PM
Sales@SonicMS's Avatar
Former Vendor of MBWorld
07 GT3RS
20 inch will fit. but recommanded to used coilover for better handling and suspension clearance. for tires size off course stretch the tires if you want to slammed the car. please call me if you need more assistance, I will be more than happy to help. since we did couple already.
sonicms llc
650 691 9000
Jastien Weiss
Old Sep 9, 2010 | 05:46 PM
threeMBs's Avatar
Only MBs - the best or nothing
20" will "fit" C class just as well as 21" will "fit" E class. Have you seen many Es with 21" on the street? Yes, correct - none. The only E with 21" wheels I saw was a picture on one of these boards from one of the "tuner" companies. When I posed the question if that car is drivable, I got exactly what I expected - no answer, 'cause its not.
I second what Luke and some others said above. Do not even think about 20s on a C, especially 240 - you'll probably will walk faster that it will drive with them on. If you realy want to have 20" wheels - change C to at least a W211 or W212(but not coupe) E sedan.
Old Sep 9, 2010 | 07:42 PM
07 GT3RS
This is a sample of my customer car with vip modular 20x8.5 and 20x9.5 inch wheels. Daily Driver. suspension set up is tein basic coilover. thanks
Attached Thumbnails offset and PCD for 20inch rims on C240?-w203.jpg   offset and PCD for 20inch rims on C240?-w203-20inch.jpg
Old Sep 10, 2010 | 11:44 AM
threeMBs's Avatar
And the tire sizes, please? I assume those things between the wheels and the ground are tires, right?
Old Sep 10, 2010 | 01:26 PM
07 GT3RS
Continental sport contact 3 235/30/20 and 255/30/20. Thanks.
Old Mar 17, 2011 | 10:49 PM
MrC.240's Avatar
2003 C240
I already got the rims on the car I just dont like running 225/30/20's in the front is there any way to fit more meat on the road with out dropping the car?
Old Aug 9, 2019 | 08:18 PM
Mercedes Benz 1's Avatar
2004 c320 benz
I have those exact same rims so all I have to do is buy the tein basic coilover kit
I have those exact same rims so all I have to do is by the tein basic coilover kit
Old Dec 11, 2020 | 04:32 PM
THICC1's Avatar
2001 C240 W203
What offset are you running on the fronts and rears, i wanna put these on mine
