E55 Ride Height with H&R Springs
Old May 20, 2002 | 05:26 AM
stephens's Avatar
E55, F550, S600 Ducati 999
Just installed H&R spings on E55 today, not harsh at all, I expected a little firmer. It actually feels more compliant on sharp edge ridges than standard Euro AMG.
Am a little disappointed that it has only dropped ride height 1/2 inch. Can I expect the suspension to settle and drop a bit more??
Old May 20, 2002 | 10:15 AM
JamE55's Avatar
Out Of Control!
stephens
What shocks are you using in combination of your H & R springs? Also pls post some pics.
Thanks!
Old May 20, 2002 | 06:59 PM
stephens's Avatar
I am using std Bilstein HD
here is a before photograph. I will do an after tonight when I get home form work
Old May 20, 2002 | 10:12 PM
Mach430's Avatar
Stephens,
Congrats on your H&R's! It is normal for the springs to settle within the first 500 miles. I would expect around another 1/4" when the springs are done settling.
If you are unhappy with the drop, you can change your the size of your spring pads. Spring pads are a rubber cushion that hold the spring in the upper perch. A smaller pad would have less cushioning, but the difference in ride quality is not much.
Most E55's come with a size 4 up front and size 3 in the rear. If you were to change to a size 2 in front and 1 in rear, you would lower the car an additional cm (5mm step between each sized pad). It is important to keep the front one step higher (430/55), as it compensates for the additional weight of the engine. You can get the spring pads for your car at your MB dealer's parts dept, or from us.
I changed my spring pads to the 2/1 and am very happy with the results. Mr. Vanos also chose to change his spring pads to a 2/1 (H&R springs and Koni Adj dampeners). Here is a picture of his car:
Ben
Old May 21, 2002 | 12:31 AM
stephens's Avatar
Thks for the tip, I already have #1 spring pads in the car.
Old May 22, 2002 | 12:02 AM
Mach430's Avatar
Give it a few hundred miles, and let us know if you are happy with the height afterwards.
Thanks,
Ben
