Snow tires for C55
Old Oct 17, 2004 | 03:18 PM
Anthonyamb's Avatar
Snow tires for C55
Hey Luke, i like to know what is the best snow tires available for the C55. I did some research but was not able to find the exact rear tire size for the C55 which is 245/35/18. What are your recommendations if I want to stick with the stock 18" wheels with snow tires?
Old Oct 17, 2004 | 06:16 PM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
The only great tire in an 18" I could find is the Pirelli Wintersport 240 in a 225/40/18 and you should run them on all 4 corners. Use a 245 and traction/grip will suffer dramatically!!! I think you would be foolish to run snows in only in the rear
A far better choice is to run 17" wheels and then there is a wide choice of 225/45/17 snows available.
I am going to run the 17" tapered 5 spoke wheel from the '05 C320 sport with 225/45/17 Michelin PA2's all around.
One thing to lookout for when buying 17" wheels is that they will clear the massive brakes that come on a C55. Many say they will but few actually do!
A wise man once said when asked about running fat 18" snows in winter. "its maybe better to not look as good and stay on the road than to be looking good in the ditch".
I hope this helps....
Old Oct 18, 2004 | 10:50 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
here's what I would recommend for your car
225/45VR17 Dunlop Winter Sport M3
17X8 Mille Miglia Bello
check out this thread for pricing info
