Will 275/50R20 fit 2017 GLE350 4matic
Old Sep 24, 2023 | 09:53 PM
MBtech2K's Avatar
2017 GLE350 4matic
My 2017 GLE350 4matic has 265/45R20 tires. I’m close to replacing my worn tires, and would like to know if anyone has installed 275/50R20s without issues like rubbing. I’m pretty sure 265/50s will fit without problems, but I’d like to go bigger if possible.
Old Sep 24, 2023 | 10:28 PM
chassis's Avatar
2017 GLE350 4MATIC
Roughly 1" larger on diameter than stock tires. AMG GLE63 with 21" wheels has a slightly smaller diameter than stock 20" tires.
While 1/2" all around less clearance doesn't sound like much, you would need to be sure of the existing clearance to know if 1/2" less will make a difference. Entering a sloped driveway from an angle with wheels turned could be a defining use case.
