Is there any difference in ride 16" vs 17"?
For instance, if you go from 15 ", likely with 65 or 60 series tire, a 16 " tire would be 50 or 55 series ( lower sidewall ), to keep the same diameter ( for your speedometer etc. ).
Going to 17 " wheel, you'd have to run 40 or 45 series tires.
The lower sidewall you have, the more responsive the handling ( faster steering response ), but your ride quality will certainly be harsher.
Where will it all stop 22", 23" 30".
