Tpms tool
Old Mar 26, 2025 | 06:35 PM
bigdog0u81's Avatar
2008 C300 6 speed manual.
Tpms tool
Is there a scanner that will tell you if one of your tpms sensors are bad? I see some but they say for Chevrolets. I have 2008 c300 thanks.
Old Mar 27, 2025 | 08:58 AM
jimyj's Avatar
E320
Yes, there are scanners out there that can definitely help you diagnose whether a TPMS sensor is faulty. The good news is that some of the more advanced models, can read the TPMS data and pull any fault codes related to the sensors. If you’re looking for a reliable option, I’d recommend checking out the YOUCANIC scanner, as it has full system diagnostic capabilities and can pull codes from the TPMS module specifically. This way, you can pinpoint if a sensor is malfunctioning or if there's another issue at play.
Old Mar 27, 2025 | 09:06 AM
bigdog0u81's Avatar
Scanner
Thanks I'll look into it. Not looking for a full-on scanner but just something that would be able to say if a sensor is bad or not.
