Michelin Pilot Sport All Season - WOW!
The Pilot Sport all season tires handled it flawlessly. I mean they were incredible. I could not believe how slick the tamped down snow was when I got out of the car. My SL just steamed ahead, I passed slow moving cars. I did drive very carefully of course, slow and deliberate, typical snow driving.
I just want to say these tires delivered on their promise - over delivered - that they have decent snow traction. For people in heavy snow areas they probably need a full blown snow tire. But I had one other experience in the snow and they were flawless then too. When I got to Whistler BC for some snow boarding I tried to make the car spin out. It was very hard to do.
I love these tires.
and the Pilot SPort A/S is also "Y" rated but, does offer significantly lower performance and grip than the "summer" variant
I did not expect the car to drive particularly well in the snow, but yes, I did expect it to be drivable (with appropriate caution). The car also performed unexpectedly poorly in a heavy rainstorm back in December.
Seems to me that cars sold in the northeast should come standard with all-season tires.
You refer to performance as being significantly lower than the summer variant. I assume you are referring to handling. What about quiet and comfort? Any differences? I may be able to live with a reduction in performance.
it is all about a phenomonon known as plasticization .... where rubber starts to harden because of the temperature. This process also makes tires harder over time due to the amount of heat cycles the tire is subjected to.
The plasticization point of summer tires varies. Some tires experience this performance drop off in an extremely sharp fashion and some are a little more gradual ... but all off them start the plasticization process at about 45 degrees
You should be able to use your current summer tires as long as you steer clear of winter rain [45F] or any type of freezing precipitation and adjust your driving style based on ambient temperatures and the amount of grip which is a good deal lower when it's cold.
A tire designed to reduce or eliminate the effects of plasticization will out perform a summer tire when the temp is below 40 degrees 99 times out of 100
if you choose to you can break alot of laws in your lifetime .... just not the laws of physics
