FS: Brand New Set of AMG Wheels four (4)
You are looking at four (4) new OEM Mercedes Benz AMG wheels; Mercedes Benz part number A204 401 4502, 7.5”J x 17” H2 ET47, 5 x 112 bolt pattern, center caps included. These wheels are from my 2007 Mercedes Benz C350 and were never used. They came on the car from the factory and were removed immediately by the dealership and have been stored in a climate controlled environment. These wheels can be used on many different applications as long as your set up can accept M14 mm bolts with a 5 x 112 bolt pattern; Mercedes Benz, Audi, Volkswagen, etc. If your set up uses M12 mm bolts, then these are not for you. The pictures you see in my listings are taken from the item(s) you will receive and not from a website or anywhere else.
Administrator
1) Was your car a 4-matic. You didn't state so.
2) C-class uses 12 mm instead of 14 mm bolts. Explain discrepancy.
X3 and 2012 C coming soon
W204s use 14x1.5 thread on lug bolts. The wheels he is selling are 17" AMGs that come with the W204 C350. Originals are staggered and these appear to be a staggered set. They will work on a 4matic or RWD.
