Sponsored by: MB Part Haus
19" AMG style Wheels by Powerwheels Pro $629
Old Aug 11, 2011 | 10:54 PM
powerwheelspro's Avatar
Former Vendor of MBWorld
E320
WHEEL SPECIFICATIONS
Size:
19x8.5/9.5
Offset: 32mm 810 style / 35mm 804 style
Weight: ~30lbs
Hub size: 66.6mm
Bolt Pattern: 5x112
Finish: 810: Gun Machined Face - 804: Silver Polished Lip
Shipping: $85
FITMENT:
C Class: W202/W203 (big brakes will need spacers in the front)
E Class: W210/W211 (stock fitment)
S Class: W220/ W221 (stock fitment)
SL: R129/ R230 (stock fitment)
E63 Style wheels:
SLR style wheels:
Size:
19x8.5/9.5
Offset: 44mm
Weight: ~30lbs
Hub size: 66.6mm
Bolt Pattern: 5x112
Finish: Hyper Silver
Shipping: $85
FITMENT:
C Class: W204
E Class: W212
S Class: W221
811:
http://s735.photobucket.com/albums/w...5102008163.jpg
WARRANTY
Our wheels are made at an OEM factory so we are proud to offer the following:
2 Years Finish Warranty: Many replica wheels finish can be sub par and the finish can crack or peel off. Since our wheels come out of an OEM process, the paint and clear coat thickness is similar to OEM standards. Obvious exclusion is curbing, denting or any other misuse that can damage or etch the finish such as use of strong chemicals in the cleaning process.
Manufacturing Defect Warranty: The wheels are made utilizing the low pressure casting process like OEM wheels do and go through rigorous quality controls including 100% x-ray, leak and balancing tests. They are guarrantied to fit on your car without vibrating or pulling.
Fitment Warranty: You don't have to know the technical specifications of the wheels your car takes, you can lean on our experience knowing what fits your car. If we get it wrong, we will support you as much as we can, or we will take full responsibility and give you a refund.
The wheels are in stock and we can also quote wheel and tire packages.
We do not make money on tires or on shipping, it is just a service we offer to our customers, we recognize not everyone has the time to drop off wheels and tires at their local tire store and waste half a day to get them mounted and balanced.
We will mount and balance them for you and take on the risk of getting it right. We have had many customers that called us after getting their wheels mounted telling us that the tire shop scratched them and asked for replacements. So we focused on putting the synergies in place that allows us to offer that service.
You can always call us at 248 686 2035 if you have any questions.
Thanks for looking!
Old Aug 19, 2011 | 12:16 AM
RaFFi ///AMG's Avatar
W124 E500 (RIP), W211 E350 (Sold), R230 SL55 (Current)
The 811 doesn't come in W211 fitment?
Old Aug 21, 2011 | 08:36 PM
kendricksoares's Avatar
mercedes benz c300
hey i would like a set of the 811 rims, however is there anyway you could maybe get them powder coated, i would like them fire orange, ido understand i would have to pay more if this was possible. please pm me and let me know. thanks
Old Aug 22, 2011 | 12:19 AM
E320
Hi Raffi///AMG, the W211 comes in 42mm offset in 8" wide wheels in the front and 9" in the back.
These being 8.5" and 9.5" 44mm offset will have the following fitment changes:
Inner Clearance: 8mm less
Outer Position: Extend an extra 4mm
Source: http://www.1010tires.com/wheeloffsetcalculator.asp
So they will fit without any problems.
kendricksoares, unfortunately we do not powdercoat wheels as a matter of policy as it would void out our 2 year finish warranty that comes with our factory wheels. Our customers are welcome to do any changes they want to them once they receive them.
Thanks,
Old Aug 22, 2011 | 12:31 AM
E320
In addition to the 19" wheels listed above we have the additional style in 19"
Style: 805 AMG Type V
Specs: 19x8.5/9.5
Offset: 35mm
Finish: Silver/Machined Lip
Old Sep 27, 2011 | 03:19 PM
tcoleman's Avatar
2003 E55 AMG
PM Sent...
Old Sep 28, 2011 | 05:24 PM
RRnelcheeze's Avatar
CLS55
you have anything for SL/CLS fitment?
Old Sep 28, 2011 | 05:35 PM
boschk's Avatar
2006 CLS500 - Iridium Silver w/ AMG Sportline
+1
Old Sep 28, 2011 | 10:28 PM
E320
Hi guys,
tcoleman, pm replied, thank you.
RRnelcheeze and boschk, your stock offset based on our sources is 25mm F and 28mm R.
In 19 the E63 style in 32mm should work.
In 18x8.5 we have these that will surely work with no spacers.
The Brabus Monoblock - Bullit in these two finishes in 30mm:
As well as the CL63 style wheels in 28mm:
Thanks,
Vassili
Thanks,
Old Sep 29, 2011 | 12:53 AM
oggie's Avatar
2011 E550 4Matic & 2010 Audi Q5 & 2015 C63 507
Which rim would work for W212 with 4matic?
Old Sep 29, 2011 | 11:21 AM
Gsc's Avatar
Gsc
2014 S550, 2014 Porsche Turbo S, 2013 Bentley GT Speed W12
Would like to know also--
Old Oct 10, 2011 | 11:51 PM
oggie's Avatar
Anyone there?
Old Oct 11, 2011 | 11:09 AM
E320
Sorry for the delay guys, there must be an issue with the notifications.
oggie, Gsc, we have the 811 AMG in 44mm offset in 19x8.8/9.5 that will fit your car perfectly.
We have one last set of those left. We will be getting more in but it is our last one for the next few weeks.
Regards,
Vassili
Old Oct 11, 2011 | 11:40 AM
Gsc's Avatar
Gsc
Regards,
Vassili
Do u have the E63 style wheels for a W212? What would the offset be?
Old Oct 11, 2011 | 11:37 PM
E320
We do have the E63 style in 18x8.5 44mm offset. The 19s are 32mm so they would look very aggressive. They would fit though if you like the aggressive look.
Thanks,
Vassili
Old Oct 13, 2011 | 05:37 AM
oggie's Avatar
Would a staggered setup work for a W212 4Matic? I thought all sizes have to be the same.
Old Oct 13, 2011 | 02:59 PM
E320
Hi oggie,
Actually this issue has been discussed with other customers and specialists. The conclusion is that as long as the outside diameter of the front and rear wheels remains the same, then there will not be any issues with the traction control or the AWD system.
Regards,
Vassili
Old Oct 13, 2011 | 05:33 PM
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
Hi oggie,
Regards,
Vassili
This means the diameter of your wheels , front and rear are the same ?
I would love to run the stock S550 staggered Sport wheels on a 07 S550 4MATIC .. What are your thoughts Vassilli ?
Old Oct 13, 2011 | 06:20 PM
aeggroup's Avatar
2025 Range Rover, 2022 BMW M850 , 2017 MB E400 Coupe
Do you have 22" for GL350 ?
Old Oct 14, 2011 | 01:10 AM
E320
Hi m4xm1l10n, you can do 255/40/19 in the front and 285/35/19 in the rear. That brings the outside diameter of the rears within 0.5% of the fronts which is negligible.
Hope it helps!
aeggroup, unfortunately we do not have 22s for your GL350. If it helps you look for the right specs, your GL takes high offset wheels, 53mm.
Thanks!
Old Oct 14, 2011 | 01:56 AM
fredyfunk's Avatar
CLK 55 AMG
Specs: 19x8.5/9.5
Offset: 35mm
Would these fit a 2001 CLK55 AMG?
Old Oct 15, 2011 | 09:46 AM
E320
fredyfunk, thanks for the interest in our wheels, unfortunately we are out of these at this point in time. We will work with our factory to get some more in.
We do have the SLR 804 style wheels in stock in 19x8.5/9.5, not sure if you like them.
Also based on our sources the 35mm will work perfectly on your car.
Thanks,
Old Oct 20, 2011 | 05:45 PM
MEAVE55's Avatar
03 E55 AMG, 10 MX-5(Sold), 06 S2000(Sold), Si(Sold), Accord Coupe(Sold), Pathfinder(Sold)
Please pm me a price + shipping for Style: 805 AMG Type V iin 19". Are these available with the AMG badge? Also need to know if they fit an E55. Thank you!
Old Oct 21, 2011 | 01:37 AM
E320
Hi MEAVE55, unfortunately we are out of those for now.
We do have the 804 SLR and the 810 E63 in stock 19x8.5/9.5 without the AMG.
In about 4-5 weeks we are getting a new shipment in with the AMG on the spokes. Not sure if the timing works for you.
Pricing is $649 for both sets we have in stock and shipping is $85. They are also guarantied to clear your brakes.
Thanks,
Old Oct 23, 2011 | 12:10 AM
tommy gun rally's Avatar
2005 E55 AMG
Are the 811 and SLR-style wheels available in 19" for a 2005 E55 AMG fitment?
