FS - RENNtech Monolite Forged Wheels
2003 CL600 2005 745Li
RENNtech's Monolite wheels are well know, considered one of the strongest, lightest, and best wheels ever made. The original cost on these was over $6000, they are a true forged 1 piece, weight is in 20 / 22 lbs range. This set was custom powder coated, they look amazing, just check them out !
I've always wanted a set of these, they are rare and hard to find, so when this set came up I took a chance that they would fit my car. They are not quite right so I am posting them to see if anyone else would like them.
20 x 9 ET 25
20 x 10.5 ET 36
These WILL fit the SL / CLS / E Class cars (E Class example on 11's and lower off set, these would not stick out as far https://mbworld.org/forums/w211-amg/...hotoshoot.html)
These will fit S / CL Class cars by going euro and running narrow tires, or rolling / pulling fenders or get the off sets changed
My CL is lower so you can see how they fit and look, I'm looking for $1900 + shipping or BO wheels only no tires
![](http://i169.photobucket.com/albums/u211/karlcbtp/W215%20wheels/IMGP5408.jpg)
![](http://i169.photobucket.com/albums/u211/karlcbtp/W215%20wheels/IMGP5415.jpg)
![](http://i169.photobucket.com/albums/u211/karlcbtp/W215%20wheels/IMGP5410.jpg)
![](http://i169.photobucket.com/albums/u211/karlcbtp/W215%20wheels/IMGP5406.jpg)
20 x 9 ET 25
20 x 10.5 ET 36
![](http://i169.photobucket.com/albums/u211/karlcbtp/W215%20wheels/IMGP5414.jpg)
Thanks, they do look good on the CL ! Tires are 245/35/20 and 285/30/20 ... I like it lowered, that's a must for me. The fronts rarely rub but the backs rub non stop.
![](http://i169.photobucket.com/albums/u211/karlcbtp/W215%20wheels/IMGP5413.jpg)
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
Really great looking wheels .. that means if you ran 275-30 -20 in the rear you should be OK right ? so what are you replacing them with ..best of luck with your sale .
Or you could run a 285/25/20 tire.. ![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
I wouldnt sell them if you really love them.. With the right tire, you can make them work.
You are running 25 on a CLS ? Thats a different car , for a CL the OEM/ stock tire diameter is different , and if one is running 35 fronts then yes the 30 is the right size to run in the rear ... of course the " real world is different for each person " but the " correct " diameter of the overall wheel from stock remains REAL .
All PM's replyed to
Also, thanks for the input on the tires but those sizes are to small on a CL class, they must be for the E or CLS class ?
Looks like the wheel may be going to a new home I will know for sure by this weekend.
All PM's replyed to
I tried it raised to FULL height and drove thru a large wave in the road at about 40+ mph and it still rubbed.
There is no EZ answer, unless I go all euro Stance Works with it and I'm just not into that.
Thanks for the input tho
