Feeler: FS/FT 18x9 HRE 563C - Brushed Clear
The W203 is giving me a headache. Going to see if anyone is interested in these wheels. I'm out of warranty and my transmission is giving me issues. Either way it's $$$ to fix the valve body or whatever else is causing the issue.
These wheels were rebuilt by HRE in October 2011. HRE installed 4 new 563C faces and 2 new inner barrel. They've check all the other barrels and it's not bent or cracked.
18x9 et 37 all around.
Made to clear BBK!
Brushed Clear
It's on Bridgestone Potenza S-03 Pole Postion (235/40/18 all around / Evenly Wear) with about 60%-70% tread left. I just wanted to see it on my car.
The wheels are 9/10 ( One have a rash you cannot see when you look straight at it, it's behind the lip )
Times this picture by 4. They all look the same![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
![](http://img717.imageshack.us/img717/5407/20111101122014.jpg)
Bad cellphone picture of the rash.
![](http://img51.imageshack.us/img51/8329/20111101122152.jpg)
As you can see you cannot see it from the front view, only if you go from the side.
It's currently on a W203. You will need a 10/12mm spacers to clear the front struts. It will probably fit other models but you'll have to make sure.
Price $3000 for wheels and tires.
Or Trade for Wheels + $$$ respectively. Not everyone have cash laying around. I'm open to other trades also, like electronics + $$.
Located in Orange County, CA.
Made to clear BBK!
Brushed Clear
To my understanding, you guys have higher offsets. I'm guessing it's to clear the BBK. You can try them out if you're local. I'm sure it should fit if BBK is the problem. These wheels was made to clear BBK. It clears my BBK by a mile!
