FS SL55 AMG Wheels $800
R230 SL55 AMG 18" Wheels.
Front 18 x 8.5 Offset ET30 - MB part # A230 401 20 02
Rear 18 x 9.5 offset ET33 - MB part # A230 401 21 02
Wheels are in good usable condition with no bends or cracks. Their are a few minor flaws (see photos)
14 Photos http://s256.beta.photobucket.com/use...20AMG%20Wheels
Asking $800/offer plus shipping.
You will want to measure your current inner & outer clearance to make sure you have enough space for the wider wheels. below is the measurements.
2005 OEM SLK front wheels are 7.5" wide with a 36mm offset
2007 OEM SL55 front wheels are 8.5" wide with a 30mm offset
you will end up with 7mm less inner clearance & 19mm extended outer clearance so about 1/4 inch closer to the front strut & the wheel will stick out about 3/4" more on the outside.
2005 OEM SLK Rear wheels are 8.5" wide with a 30mm offset
2007 OEM SL55 Rear wheels are 9.5" wide with a 33mm offset
you will end up with 16mm less inner clearance & 10mm extended outer clearance so about 5/8" closer to the rear strut & the wheel will stick out about 3/8" more on the outside.
My guess is you will have the extra space for the wider wheels but you will want to measure to make sure.
