Sponsored by: MB Part Haus
FS: brand new 20mm hubcentric spacers with extended lug bolts
Old Sep 17, 2013 | 04:52 AM
steadysupreme's Avatar
2013 GL350 Bluetec
Hi, just a set of 4 (2 pairs) brand new 20mm Novustech hubcentric spacers with extended lug bolts. Centerbore 66.6, bolt pattern 5x112.
$240 plus shipping.
Novustech is Canadian products, made of lightweight aluminum and anodized to prevent rusting. Excellent quality pieces.
Old Nov 23, 2013 | 10:31 PM
2013 GL350 Bluetec
feel free to offer me, they are collection dust.
Old Dec 5, 2013 | 07:49 PM
xsboost's Avatar
2009 G8 GT 2004 E55 AMG
I know they are not the same quality. But this is the problem.
china can make a copy of anything.
I only need 2 spacers and 10 lugs,
I am in Allentown Pa 18104 USA what would you take $$
http://www.ebay.com/itm/2-Pc-20mm-Thick-Hub-Centric-Wheel-Spacers-For-Mercedes-Benz-66-6-W-10-Lug-Bolts-/261340396901?_trksid=p2054897.l4276
Old Dec 5, 2013 | 08:03 PM
2013 GL350 Bluetec
Sorry can't compare, you are at risk if you buy those spacers. Hubcentric lip are really easy to crack on those ones.
I will check shipping tmr and get back to you asap. But i won't be selling close to that price.
Old Dec 6, 2013 | 02:48 PM
edcarls's Avatar
97R129-01W163-94E320-93500E
Originally Posted by xsboost
You can by 3 sets and it still cost you less and you'll have spares in case the hub-centric lips crack as suggested.
Old Dec 6, 2013 | 06:25 PM
2013 GL350 Bluetec
Well you can think of it that way, but for me personally, is always safety first. Better do it right the first time and better be safe than sorry, right?
Old Dec 19, 2013 | 05:09 AM
2013 GL350 Bluetec
bump.
Old Dec 19, 2013 | 12:02 PM
edcarls's Avatar
The picture shows a different type of spacers (DRA) wherein the wheel is bolted to the spacer and the spacer bolted to the hub. The one for sale, the spacer is sandwich between the wheel and hub using the correct length wheel bolts. The spacer carries no weight; the wheel bolt does.
As long as the spacer is hub-centric, and you use the correct size bolts on a non-DRA spacer, I don't see how
the catastrophic incident depicted in the picture would happen.
Again good luck with your sale.
Old Dec 19, 2013 | 05:37 PM
2013 GL350 Bluetec
and on top of all that, is cheap material.
Also, not referring to the picture, but there are incidents that cheap quality spacers do crack where the hubcentric lips are. I did my research before purchasing this pair since i am a safety first person.
